620 Front Hydraulics
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 620 Front Hydraulics
    Posted: 04 Sep 2015 at 10:35pm
Today I put the front mounted snowblower on the front of my 620 since I bought the package 5 years ago.  However I have a problem.  The hydraulic cylinder does not lift up the snow blower, it only pushes it on the ground more (raising the front axle off the ground).  I tried switching the hose connections at the front of the tractor, but it makes no difference.
The remote ends on the tractor are brand new and the balls on the male connectors move when pushed (one squirts oil out, the other doesn't).  It seems the lift control does not do any thing when you move it to the lift position (pull back towards the operator).  It works in the lower position.  However, there were times that the cylinder would not move when set in the float position.  To me, it sounds like a problem with the connections at the front of the tractor.
Any Ideas?
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:17am
Would one of the lines have unbled air in it? I don't really know but just guessing. Good luck.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 11:30am
You should have oil flow out each when you move control valve to either position. If you don't, Valve has a problem. Which is odd for spool type valve.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 4:15pm
try hooking up your three piont cylinder and see if it works  if it does the packing ont the piston in cylinder is blown
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 9:54pm
Problem solved!  One of the hose couplers on the snow blower was slightly shorter and would not fit into the remote all the way.  I like easy fixes!
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 12:08am
That was a real blessing in disguise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 12:41am
Myron,
That's a pretty serious snow blower man!  You'll move some snow wit' dat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2015 at 9:51pm
52" worth Steve!  However the floatation tires on back are WIDER!  Probably won't see too much snow.  The 6080 with cab and a 7' snowblower gets the job done without freezing your tail off!
This page was generated in 1.258 seconds.
