620 720carb
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 620 720carb
    Posted: 13 Jul 2020 at 2:47pm
Anybody have a good carb off a cckb 620/720 they would want to donate to the cause? Finally try to get my tractor running with the nos pump motor.
scott 11224 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott 11224 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 7:58pm
I haven't tried it yet but there has been a lot of success with using a $20 carb on e-bay (china) I believe it is for a Kohler 582 twin? I bought one but have not tried it. If you go on facebook you can join the 616,620 and 720 sight, I believe it has some discussion on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 8:08am
Ok, I found that page now and the carb they recommend. Does your original carb have a flange adapter bolted to it for the rubber boot to the filter housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott 11224 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 5:04pm
Yes it has the air cleaner hose. Like I said I have not tried it yet but from what I have read the only alteration is to open the air holes. Did you find the article on the FB website?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 5:18pm
I did not see an article
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 11:36am
I believe this is the carb everyone is using on the conversion. Although it can be found much cheaper on Ebay.
https://isavetractors.com/carburetor-for-kohler-k482-k532-engines-18-and-20-hp/
Two of the holes on the face have to be opened up to meet the inlet, using a dremel or a file. If you compare it to your stock carb, you'll see which holes we're speaking of.
GB :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott 11224 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 1:49pm
You are correct, I bought mine on E-bay for $25 with shipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott 11224 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 1:50pm
The article on FB 616,620,720... was by Jesse Grecco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 1:58pm
I have read that there are definite quality differences in the Ebay carbs and the Isavetractors version of the carb. I have no experience with this myself just yet. I've also read just how happy the owners are with their tractors after swapping to these carbs.
GB :)
