616H Hydrostatic oil capacity |
Brampton 02 gt
Joined: 07 Apr 2011 Location: Erin,ON, Canada Points: 321 |
Topic: 616H Hydrostatic oil capacityPosted: 18 Jan 2014 at 9:36am |
Does anyone know the capacity? I am going to give it an oil change. I was going to use a case/nh hytran I have. I need to get an owners manual
thnaks |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 23 Jan 2014 at 8:55am |
It has a Eaton Hydrostatic unit - think it is around 2 1/2 qt . I used ATF in unit . it does have the vent cup where you add oil till full.
The Hydrogear Transaxle in another mower i have uses 20/50 motor oil and the Vickers unit in my New Holland uses 10/30
John Ontario Canada
Joined: 04 Jan 2014 Location: Midland Ontario Points: 31 |
Posted: 23 Jan 2014 at 10:26am |
Call Country Air and Repair in Moorefield. They are not far from Mount Forest. Very knowledgeable people. They are a Simplicity dealer.they can tell you the info and might even find you a manual. 1 519 638 8941. Good luck. John.
rooster
Joined: 18 Dec 2010 Location: north carolina Points: 15 |
Posted: 05 Feb 2014 at 8:38am |
Mine has the filler neck and cap. sombody has put 5w30 and 0w20 and what ever was laying around in it and when it warms up it getts sluggish. what should i do.
Coke-in-MN
Posted: 06 Feb 2014 at 10:49am |
Try 20/50 - to see it it helps -
