616 Running hot |
Tom6070
Joined: 11 Sep 2009 Location: Kendallville IN Points: 53 |
Topic: 616 Running hotPosted: 29 Apr 2014 at 9:27pm |
Hey Guys,
My 616 has a good running original Onan engine. It seems to be running a little hot. Backfires when shutting it off. Anybody have any ideas? I plan on replacing the engine in a few years. Thanks, Tom |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10933 |
Posted: 29 Apr 2014 at 9:40pm |
Carbon buildup on the heads probably.Might have timing off slightly and cooling fins clogged up. HTH Tracy
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 30 Apr 2014 at 6:36pm |
mines done it since I bought it in 2000,i'm thinking carbon to but still have never had head off,maybe this year
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 07 May 2014 at 12:10am |
Back firing isn't really a running hot issue. Any little flake of carbon or oil residue buildup can cause this. A lean carb will mare it pop and backfire while lowering throttle or at shutdown. Btw, a lean carb will also make it run above normal temp.
Yea, I can fix that.....
