616 not charging |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: 616 not chargingPosted: 20 Aug 2015 at 8:48am |
The 616 I bought this summer is now showing a draw on the amp meter when the clutch/lights are engaged. Where would you guy's start trouble shooting?
Thanks! David
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 27 Aug 2015 at 7:12am |
Start right at the Battery. The Battery might be on its way out. Slow charge the Battery to full, wait 20 minutes or so and pull a draw test. If it flunks the draw test, there's your culprit. If the Battery passes the draw test, you may have a wire or wires grounding on the chassis. Especially in the engine box area. Pretty tight in there! Take the circuit breaker out of the Battery feed circuit (by-pass it) and see if it stays the same. If it stays the same its not a bad circuit breaker or connection at the breaker. I think you installed a new flywheel and stator didn't you? Or, is this the newest one you picked up?
coggonobrien
Posted: 27 Aug 2015 at 8:58am |
This is on the newer tractor but I do have the hardware from the old. I threw in a known good battery and its still draining. With the front clutch engaged I'm at -4amps with the lights and front clutch -10amps. funny thing is I have never had it shut off while using it but you can tell the engine does not sound right after running a while, ignition sounds weak.
Steve in NJ
Posted: 29 Aug 2015 at 7:45am |
Might need an Ignition switch Dave. That's pullin' a lot of amps off such a small 15 amp system. Ignition switches get a lot of corrosion around em' especially if its the original. Its a popular item with us in our 620 parts section. See if the switch is getting warm or hot.
coggonobrien
Posted: 29 Aug 2015 at 8:55am |
Are you talking the key switch? I have had an issue the whole time whereby ou hit the key and hear the starter hit but not turn. Then after a few it takes off. I assumed it was a starter issue.
coggonobrien
Posted: 31 Aug 2015 at 7:55pm |
Steve, can you send me a pm with price shipped 2 day priority for the ignition switch? Also does your complete wiring harness kit come with the ignition?
coggonobrien
Posted: 03 Sep 2015 at 9:26am |
well the problem progressed over the weekend, now the tractor will not start but has full lights. I can hear the circuit breaker trip and reset so I guess I have to look for a cracked wire.
