616 Hydro
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 616 Hydro
    Posted: 03 Apr 2010 at 8:20pm
Duetz-Allis 616 Hydro has begun to slow up speed wise (Ground speed).
Fluid level is OK, but probably need to change the fluid as it has been a while since the shop did it. Do these mowers have a hydro oil filter?
Any ideas on what would cause it to move slow? Has to be flow related?
Charlie
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 9:35pm
Wear in the linkage could result in a slow decrease of speed. If you have a noticeable difference in a few days of use I'd look at the drive belt adjustment/wear.
If you do have a pump problem your likely better off finding a complete tranny and swap out rather than trying to dig into the hydro due to the clearances and possible contamination involved in a hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:21pm
I will check that.
The manual doesn't say how much oil goes in it, do you know?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 8:30pm
I don't, however you can check out Simpltractors.com and post the question and I'm sure you'll get some more info.
This page was generated in 0.424 seconds.
