616/620 alternator conversion |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: 616/620 alternator conversionPosted: 08 Apr 2016 at 7:02am |
Can somebody point me in the right direction of somebody that has done this? I'd like to start a swap on my ccka and want to check mounting and pulley info.
Thanks! David
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 08 Apr 2016 at 1:58pm |
if mine goes bad and i still have a onan in it i am going to mount a pulley on the pto shaft put a gyro and reg off a kubota on it between clutch and trans. that was my thought. some have put a smallersize battery in and mounted a small denzo alt in the battery tray with a pulley on the crank
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11397 |
Posted: 08 Apr 2016 at 2:09pm |
720nut done it to one of his. I believe the he had a write up about how he done it on the SimplicityAC page.
coggonobrien
Posted: 08 Apr 2016 at 3:18pm |
hudco that's what i'm planning for. mine hasn't failed that i know of yet and i do have spare parts but I really don't want to pull the engine again.
Thanks tadams
coggonobrien
Posted: 08 Apr 2016 at 3:33pm |
tadams you got a link to that home page?
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 08 Apr 2016 at 10:32pm |
google: simpletractors.com
HudCo
Posted: 08 Apr 2016 at 11:01pm |
that is were i seen the alt was on simpletractors was looking while i was gassing up to sub soil the garden before i take the duels off and i think one of those little gyros would fit up front on the right side with out haveing to use a smaller battery
coggonobrien
Posted: 09 Apr 2016 at 7:50am |
Does direction of rotation matter with an alternator
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 09 Apr 2016 at 12:17pm |
That's what my idea started out as. Mounting a small Denso up front on a seperate pulley. I did take a couple pics, but being I was still in the designing stages yet when the cold weather set in, I haven't had the time to go out and doing anything yet. Between the high winds we were getting and the cold snap, I've been busy at work keeping out trucks going so the linemen can stand poles back up again and hang new wire. I'll get back to it this Spring if it ever warms up again. I have a few idea's in mind...
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 11 Apr 2016 at 6:13am |
I've got my build documented on Simpletractors. It is a Densco mini alt with 420 amp L&G battery for space. Mine is also a dedicated loader tractor so I replaced front clutch with a pulley so as to have live hydraulics, I'm sure same can be done with clutch. Here is address to thread simpletractors.com/club2/topic.asp?TOPIC_ID=154806
Edited by ac720nut - 11 Apr 2016 at 6:17am |
