616/620/720 rear pto function |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: 616/620/720 rear pto functionPosted: 17 Feb 2016 at 9:47am |
Just wondering should the rear pto turn if there is no implement hooked up and you hit the switch?
Thanks David
1953CA
Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
Posted: 17 Feb 2016 at 11:28am |
you should turn it on id say once a month, but run it with no attachment continuous, no...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
coggonobrien
Posted: 17 Feb 2016 at 11:50am |
so you are saying turn it on to basically make sure the clutch is free, but it will not turn without an implement?
