616/620/720 mower deck question |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: 616/620/720 mower deck questionPosted: 08 Jun 2016 at 8:11am |
on my deck, one of the adjusting handles actually moves freely when i'm mowing, the spring appears to be intact but i have not disassembled it. do you guys think it's the spring or something else?
Thanks
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 08 Jun 2016 at 10:25am |
are you referring to the adjusting handles for the rear rollers? If so, there is no spring for them. Can you clarify or give a picture of what you are looking at?
coggonobrien
Posted: 08 Jun 2016 at 10:40am |
yes the height adjusting handles. what is the function of the spring on the shift under the t-handle?
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 08 Jun 2016 at 11:05am |
The spring is there to hold tension on adjusting screw. Vibration of deck will turn them with tension over time. If spring is weak, adjust it where you like, put a jamb nut on bottom. That will fix the problem. HTH Tracy
DSeries4
Posted: 08 Jun 2016 at 11:56am |
Tracy Martin TN
Posted: 08 Jun 2016 at 1:03pm |
There were two styles of adjustments on those. I have both kinds. My unmolested pristine deck has springs, the others don't. I think the lenght of tube was shorter on the ones with springs. HTH Tracy |
coggonobrien
Posted: 09 Jun 2016 at 7:42am |
tracy is right, thanks for the advice tracy
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 11 Jun 2016 at 8:37am |
Another one of those little items that are overlooked. These Tractors have so many little subtle differences, it makes ya scratch yer' head till yer' bald! If it ain't wiring, its switches, or routing. Now its mower decks. Sheesh! And, btw, the center of my head is getting pretty shiny up there.... LOL!
