616/620/720 front electric clutch |
Darrell, Jr. (MN)
Joined: 11 Sep 2009 Location: Arlington, MN Points: 234 |
Topic: 616/620/720 front electric clutchPosted: 23 May 2018 at 11:58am |
The front clutch on my 620 went out last night, what's out there for new/used, and what are the going prices? |
Tom IA
Joined: 17 Sep 2009 Location: Donahue IA Points: 255 |
Posted: 24 May 2018 at 3:56pm |
some of the parts are still available not bearing, had to go with a different bearing bushed the housing and made a couple spaces check with Sandy Lake
Darrell, Jr. (MN)
Posted: 25 May 2018 at 11:33pm |
Thanks Tom, I was starting to think no one has ever replaced a clutch on one of these...lol...I will look into parts |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 26 May 2018 at 5:55am |
hmm.. just stopped ? Check for a broken wire. Most electric clutches draw about 3 1/2 to 4 amps of current. I've rewired a few,not hard but a long afternoon's labour. Only cost was $10 of copper wire and $5 for the 5 minute epoxy.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5477 |
Posted: 28 May 2018 at 8:55pm |
I need to learn how to rewire one. I have 2 720’s and use them on a regular bases. Sickle mower and rear tiller at the moment. Utube video?
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 29 May 2018 at 5:52am |
Mike Brown in Wisconsin has a line on rewiring clutches
Darrell, Jr. (MN)
Posted: 01 Jun 2018 at 9:19pm |
It's not the electrical part of the clutch that's bad, it's one of the spring steel alignment fingers that broke.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 01 Jun 2018 at 10:51pm |
It can probably be fixed. Tracy
Darrell, Jr. (MN)
Posted: 02 Jun 2018 at 11:31am |
I have already tack welded it once, I would hate to put too much on it and throw the balance off and wreck something else. |
Tracy Martin TN
Posted: 02 Jun 2018 at 7:47pm |
Darrell, it is riveted at each end? I don't remember how that clutch looks at moment. Lots of them can be fixed with proper procedure. HTH Tracy
