616/620/720 engine belt install
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 engine belt install
    Posted: 18 Mar 2016 at 7:51am
any tips for getting the things on?  seem like a major pain with the engine unbolted.  also what is the purpose in the fiber disc bolt to the pulley on the fly wheel?
Thanks
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 8:49am
I thought the fiber disc in there was for vibration purposes. The smaller garden Tractors have em' to. That really was my own perspective on that. As far as the belt, I haven't put mine on yet. My engine is just sitting in the Tractor right now, but I gotta' pull the engine back out again and make sure the Starter engages correctly before I bolt that puppy in for good...
Steve
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 11:33am
With the engine mount bolts off and the driveshaft disconnected, you should be able to just tip the engine back to get the belts on. I used this procedure also to remove the belts.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 11:39am
what do you mean by drive shaft disconnected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 11:51am
coggonobrien: The front driveshaft coupler to the engine pulley which is probably already disconnected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 1:31pm
gotcha, thought that was what you meant but i secretly hoped the was another point that made it fall together :)
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 4:55pm
I'm guessing that you mean the pair of belts off the engine.  After fighting the on a couple motors, we found the easiest way is (with engine bolted in place) to have the twin pulley off the engine, put the belts on both sets of pulleys (top and bottom) then hold the clutch petal down.  This will let you put the pulley back on the engine.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2016 at 6:24pm
The fiber disc is for misalignment. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 7:46am
well I got them on but I need to readjust the tensioner.  How tight should I take it?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 11:03am
spring hieght 7 3/4 before running engine 8 inches after running engine  clutch pedal out belt stop clearance 1/4 before running engine 1/16 to 1/8 inch after running engine  clutch pedal out        pulley clearance 1/ 16 inch  clutch pedal in        those belts will wear in the old pulleys very quickly so it will not be long before it needs adjusting again then it should stay along time
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 11:07am
Ok so what process did you use to get belts on ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 11:10am
I had already completely loosened the tentioner.  I hung both belts from the engine pulley with it installed on the engine.  Was able to get the front belt on by tipping the engine myself then went underneath the tractor with Dad working the top side and slipped the rear on.  Went pretty well with the tensioner loose
BrianC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 5:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 7:07am
Thanks Brian
This page was generated in 0.477 seconds.
