615 rear wheel weights?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: 615 rear wheel weights?
    Posted: 17 Sep 2013 at 9:02pm
What rear wheel weights will fit a 615? I found a set of weights and rims off a CA, would these fit? Currently, the tire size is 16.9 x 24. While great on pavement, I lose traction in the dirt while hauling manure. I plan on buying new tires this winter, would you keep the same size?
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2013 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2013 at 10:50pm
I have a photo of the weight we removed from our 615 which is an OEM weight, however the file is to large for this window. Very heavy flat on one side, dished on the other to fit the industrial rim. (non adjustable)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2013 at 7:45pm
Thank you for the information. I was hoping that a more common agricultural weight would fit as I imagine the industrial ones are more difficult to locate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2013 at 8:30pm
I would think ca and d-10/12 would fit, and perhaps farmall weights.  Might have to drill a couple/4 holes per rim.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2013 at 10:12pm
Here is what the proper weight looks like....and they are heavy!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2013 at 3:16pm
Wow, those do look heavy. Anyone know what the casting number is, AM.....? I would like to check the local salvage yard.
I don't suppose either of you, or anyone else reading this would like to sell a set of weights for the 615? If so, please reply here or PM me.
Thanks
This page was generated in 0.219 seconds.
