615 diesel metering valve info?
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 615 diesel metering valve info?
    Posted: 21 May 2023 at 9:11pm
I have a 615 4 cyl diesel it has been sitting for 3 yrs  I drained the fuel replaced the filter im not getting any fuel up to the injectors  I cracked the lines no fuel  I can hear the solenoid on top of the pump click when the key is powered up.  would the metering valve be my problem?  Location of this valve and can it be cleaned?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:16pm
I think if it's a Roosa you can unstick the metering valve buy removing top of pump but I don't know the particulars. Some knowledgeable person will have your answer.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:28pm
Metering valve can be freed by removing top of pump, but if pumping plungers are stuck, that is a complete tear down.                       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:39pm
take off the top cover and I assume its a threaded screw?  remove and replace at the same thread count? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:46pm
found it I googled the pump found a break down of it
This page was generated in 0.088 seconds.
