6080 |
Acguywill ![]() Bronze Level ![]() Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 148 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2024 at 10:55pm |
Am looking at an 83 allis 6080 fwa open station loader tractor. Has 2700 hrs on it, looks ok tires are original and getting cracked needs seat and has regular wear and tear for a 40 plus year old tractor. What is it worth? Dad had a 2wd one with a loader on it when I was a kid and I always wanted to get one with fwa. Dad sold ours to an uncle when it had about 6500 hrs on it and the only thing I can remember fixing on it was a head gasket. My uncle ran it for years and scrapped it when the transmission piled up with around 20k hours on it. Anyway just looking for an excuse to buy this one.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Those are still pretty popular and this ones low hours, just guessin in the $12,000- $15,000 range ; alot depends on paint etc; just an opinion and watching online auctions
Edited by DougG - 16 Jan 2024 at 7:30am |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5025 |
Value is very much related to your area.
One of my cousins recently (October) bought a 6080 FWA with a cab, in fair condition. The tractor runs and drives well. He bought it from the guy that owned it's widow. She said her late husband bought it new and, for the last several years, he used it only on a JD round baler. He gave $6500 for the tractor, but AC tractors in our area don't sell very high.
The one I am looking at is priced at the high end of that range. The guy that owns it now bought it from his father about 10 years ago. His father bought it from the original owner around 2000 and it had most of the hours on it at that time. The owner is solid on his price and said he would sell it at auction if he doesn't get it. I don't think he will realize his asking price at auction once the fees are removed but he is willing to roll the dice. I could wait it out but the tractor is in acerage country and has a loader and fwa and compared to new/newer stuff is relatively cheap so I am not sure it will stick around for long. Not many of these tractors around here and might be a long time before something better comes along. I haven't looked at it yet as it is 5 plus hours away and the weather has been to cold to venture out that far. Don't really need this tractor but it would be a nice addition to the fleet.
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2576 |
here's a nice one with a loader for 10,900 in Michigan.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3536 |
Edited by AC7060IL - 16 Jan 2024 at 11:11am |
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
Does it compare to this one?
https://www.kijiji.ca/v-farming-equipment/strathcona-county/allis-chalmers-tractor/1680495888 |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Actually that is the tractor. I just mixed up the hours with another tractor I was looking at. The owner said it's in working order but the pto leaver is not working quite right. Most likely just rusty from lack of use.
In response to AC7060IL's comment about the thrust bearing kit; was that factory installed on later builds? Dad's I think was bought new in 85 (had deutz allis stickers on it) but I can't remember if it had the bearing or not.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3527 |
The front bearing kit - the first 6080's failed the thrust bearings. Then they went to slotted bearings - this did not fix the issue - THEN finally they went to a wider thrust flange and wider corresponding thrust area on the crank. For the earlier ones that survived w/o too much damage, mostly due to slow starting with the foot clutch and PTO clutch depressed and way too much thrust, there was a front support/bearing set up that took the pressure off the thrust bearing and put it on the cone/cup front bearing (that had a grease point a lot do not know of) . There was a roll pin that failed and the roll pin was replaced with a solid dowel pin. 6060's faired better due to less pressure but we installed the kits on all we sold. This issue arose because testing did not show this failure due the amount of hours put on quick, plus there had never been an issue before. This cost AC more than a million. Tractor division had to foot the bill - not the Harvey engine plant - another 'straw on the camels back'. BUT they fixed the issue and left no farmer holding the bag$ that I know of. **PRIOR ENGINE S/N 33K-21863 was the cut in sn DOWEL PIN IS PN 70268703 also there were a number of F2 Combine engines swapped into 6080's -most did not have the wide flange and the uninformed did not swap the front support. The 6080 was the highest market share tractor AC had in the 'modern ere'. Per Ed Swingle the 6000 series had over 20 % market share at times - WAY above other models.
Daehler ![]() Orange Level Access ![]() Joined: 23 Nov 2010 Location: Lexington MO Points: 1160 |
Easily worth 15k with those hours. Great tractors that just run forever if taken care of.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
6080fwa ![]() Bronze Level ![]() Joined: 10 Apr 2018 Location: Alberta Points: 79 |
i have a late model deutz allis 6080 that the upgraded thrust bearings failed on in the the block. I bought it that way. no outer support on it. the block was worn into, this was over 10 years ago. i swapped a low hour f2 engine in and keep the pto in the fwd position, no problems since . checked crank play every couple years and it hasnt changed any.
They are a reliable tractor with great traction with fwa. hard to beat their fuel efficiency if u keep the rpm below 2000 you can bale a long day with a full tank, way better than any other allis of that or greater hp. They are a torquey tractor. i have 4 of them. Get one with a factory cab if you can.
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1586 |
It seems a lot of A-C people don't like the 6000 series because they were part Fiat, part Allis. It's not like this was a new thing in manufacturing. There are other Allis models that were not 100% A-C but they don't seem to get the same disrespect the 6000 series gets. Every brand did the same thing to some extent with certain models. It still goes on even today. They had their quirks but they are great tractors if taken care of.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5232 |
Our father bought a new 6060 in 1981. AC failed to notify him of the front thrust bearing repair. Our local dealer never mentioned it which has always been a sore subject for me personally. Not sure which one mishandled it but regardless it was never addressed. With that being said, if the pto, pto disconnect lever are used like the manual explains, we were told there would be no issue. The problem occurs when the pto disconnect lever is left in the disconnect position for long periods of time putting extra pressure on the front bearing. If it is used correctly then there should be no issue. The bad, the front bearing support is NLA. Really good tractors as long as they are operated as designed. Is it a flaw, absolutely, but use the pto disconnect lever as it was intended and there shouldn’t be an issue.
If he bought it in 81 it wasnt an issue yet , think the problem started to surface in probably late 82-83 with 6080,s; just things Ive heard of this issue ; as far as being part Fiat no problem here; got a 6080 that I really like now,was kinda disappointed in it at first because of keeping the engine over 1800 rpm,s to keep the real power going -and just gotta service it as AC said to; that sycro 12 speed trannys awesome !
Edited by DougG - 18 Jan 2024 at 5:48am |
Jasonw ![]() Bronze Level ![]() Joined: 11 Dec 2017 Location: MD Points: 62 |
The parts needed for the front bearing support are still available from AGCO individually but for everything you would need it would cost over $1,400.
First off thanks for all the help, I just joined the forum and wasn't sure how active it was but seeing all the responses has been nice. Now back to this tractor, a cab would be nice but I have never seen one with a cab in person. Does it only have the one door? The reason I ask is because I would be using it as an auger tractor and having to climb into the cab to start and stop it would get old fast. Right now I use a massey 461 on the small auger, (13×85) and everything is accessible from the ground from either side but the tractor is short on power. Engine start/stop and throttle would be easy enough to rig up for external control but haven't quite figured out how to engage the pto. I have some ideas but without having a tractor in front of me I'm not sure it would work. Speaking of fuel efficiency I just sold a jd 4455 because it was such a fuel hog. Have a 8010 allis on the bale processor and can feed and bed 200plus cows for 5 months on less than 3 tanks of winter diesel.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
Yes, it only has 1 one door. On the left side. PTO lever is on the right side. Edited by DSeries4 - 18 Jan 2024 at 12:30pm |
It's not a good auger tractor.
Why not ? As long as you keep everything lubed and workable - never had problems with the pto
It's not a good auger tractor because of the layout of the controls or are there other issues with using it for that purpose? The one dad had was mostly used for pto work.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
I’d love to know how many hundred of hours we put on our 6080’s doing auger work.
The pto lever sucks for an auger. How are you going to engage/disengage it standing beside the tractor?
What if there is an emergency? Could your wife or a child pull that lever standing beside the tractor? Any auger tractor I use has a push/pull switch that you hit to shut the pto off instantly. Safety first. There are a lot better choices out there...pick another tractor. |
Not uncommon for me to spot a semi and wife to unload it herself she manages fine. Not ideal but son could turn off the key….Id say 50/50 if he could pull the lever back yet but soon he could. He’s a good resourceful person so who knows. Daughter to young to respond no matter the set up. Only bad thing about a 6080 on the auger is the clutch safety switch.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4091 |
Take this advice for what it's worth but I try hard to NEVER start a tractor from anywhere but the seat!!! We lost a local Oliver guy recently, was starting his 1855, (I think) standing in front of the tire, ran right over him as it was in gear. Also know a father and son that had more than a close call with a 966. Dad got knocked out of the way, son got hit enough to wind up in the hospital and using a walker for several weeks afterward. I know it can be a pain getting on and off but **** happens quick!
The little massey has interlock switches so it will not crank over unless it is in neutral and the pto is disengaged. Interestingly it does not have one on the clutch pedal so no need to push it in to start the tractor which makes it so handy for auger use. I think only the newer tractors with electronic pto engagement have the push button shut-off, the oldest tractor I have with that is a 1998 model. Anything that new would be priced out of range for my application. If I remember correctly the 6080 shuts off with the key so an emergency kill switch could be mounted anywhere.
Safety is important but it, like art, is in the eye of the beholder. What is safe to one person may seem completely nuts to another. To me most things are safe as long as you pay attention to what you are doing and know your limitations. |
If you don’t feel they are safe by all means don’t buy them. Less people buying the 6,7, 8000 series the better for me. Less demand should make them cheaper for me.
Does anyone know if the 6000 series tractors came from the factory with 4 or 5 digit hour meters? My brother went and looked at one yesterday and it was a 5. Just trying to figure out if it the original or if it was replaced at some point. Tractor looked OK but had lots of old tractor issues; lights, seat, oil leaks, steering pin wear (FWA), etc. It has been used on an acerage for years but I think it was used pretty hard earlier in its life. The loader has some cracks and is plated in spots it is also tweaked a bit. It is a usable tractor but could use some tlc.
ranger43 ![]() Bronze Level ![]() Joined: 09 Jun 2019 Location: Huntingburg Points: 154 |
I had a 2wd 6080 C/H/A for a few years it was ok. Fiat put the trans shifter on the left hand side and range shifter on the right just bizarre set up in my opinion, plus can't feather the 3 point hitch like the 100 series. Bought a low houred 185 and enjoy it much more. The 6080 was very fuel efficient though
