6080 Won't Start
Nbeal43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nbeal43 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Won't Start
    Posted: 18 Aug 2025 at 11:41am
I have a 6080.  It was running fine, under power, but then began losing power slowly until he engine died.  Two minutes or so later, it started again, but soon repeated the power loss and failure.  After this happened twice, I verified that fuel was flowing unrestricted to the fuel filter.  I replaced the filter, but engine would not start.  I then bled the sytem of air, and I have confirmed there is free flow of fuel to the air release valve on the fuel injector, but the engine will not start.
I realize now that bleeding air from the fuel filter and at the connection to the injection was should have occurred before trying to restart.  I don't now if that in itself may now be part of the problem.
I am dead in the field now.  Advise will be greatly appreciated.  My phone number is 816-560-9002 if conversation may be preferable to written suggestions.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 12:17pm
Loosen injector lines at the injector and crank till fuel is to the injectors
Edited by SilverShoes - 18 Aug 2025 at 12:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 12:54pm
Sounds like the symptoms of the elastomer governor going to pieces plugging the return line. I don't know if that pump has it. Some versions don't. Loosen the 2 screws holding the timing window so it can bleed off pressure and see if it runs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nbeal43 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 12:48pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nbeal43 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 12:52pm
Thanks.  It took a bit of advise from a local Allis guy to understand your suggestion.  He agrees this likely is the problem.  Before checking it,  I am going thru the process of confirm there is fuel at the injection points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 1:32pm
Crack the injector lines at injector and crank with the fuel on. It won't be a flood of fuel but will produce enough to make a mess.
This page was generated in 0.158 seconds.
