6080 with poor hydraulics
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 6080 with poor hydraulics
    Posted: 17 Jan 2026 at 3:45pm
One of our 6080’s has very poor hydraulics.   Steers perfectly fine.   Had it on the discbine this summer and it would struggle to lift it most of the time but not all the time.   Fluid level is good and filters are new.   3pt got lowered  this fall and couldn’t lift it back up till randomly one day it raised.  Put gauge on the remotes and tested after start up.  We’ve switched remotes around but in the end I think problem shows up with both.  When I find my notes on pressures I’ll update post.
Found my notes:   Tested at start up from sitting a couple days 2200-2300 psi but after running a bit dropped down to a max of 1300.
Where does a person go next?  Someone suggested too much play in the rod to the valve stack but doesn’t look bad.
Edited by victoryallis - 17 Jan 2026 at 3:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 7:31am
Start by rebuilding or replacing the relief valve on the remote spools valve stack. This relief valve should be identical to what we used on series 4 D-17's-170-200's etc. They are still Husco brand valves. Knowing that the good relief valve is now in that 2200 psi range, if the hydraulics still don't perform as they should, there is clearly a problem inside the lift section of the hydraulic pump. This assumes clean filters and full of oil in the rear end.
This page was generated in 0.162 seconds.
