6080 steering wheel help
G_Lipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G_Lipe Quote  Post ReplyReply Direct Link To This Post Topic: 6080 steering wheel help
    Posted: 28 Nov 2009 at 12:25pm
I'm trying to remove the steering wheel off of our 6080 to replace the instrument panel and it wont budge. I was finally able to remove the nut using an impact gun however i cant get the wheel itself off.  Just an FYI this tractor was stored outside uncovered without the plastic wheel cover for God only knows how long before we bought it so i think the spline is rusted up real bad.
Any ideas are welcome also if anyone knows where i can get a new wheel for after i screw this one up that would be appreciated
thanks
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 3:29pm
generally speaking, I find a 3 jaw puller works the best. I'm assuming that you already have sprayed the threads and spline with the lubricant of your choice. Get the puller on there and tighten up the screw on the puller tight enough to put some pressure on the wheel, but not so tight that you screw up the wheel. Then take a hammer and give the screw on the puller a good whack on the end. A few good swats should pop the wheel off the column. It's tapered so it won't loosen up it will just fall off. If you'ed wrecked the wheel already any one of the advertiser's on this sight will be able to get you a new wheel. Good luck
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Edited by kev/ont - 28 Nov 2009 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote G_Lipe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 4:20pm
thanks i havent screwed up the wheel yet, i'll have to get a puller i was working on it earlier with on success so we'll see how that goes
ScooterBuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:13pm
Good advice above. Make sure you use some sort of penetrating fluid numerous times. If the wheel has some threaded holes in it (not familiar with this steering wheel) like a lot do you can use a bar puller with two bolts and that would be easier on the steering wheel than a jaw style puller. A bar puller would also allow you to apply more pressure. I have pulled up on the steering wheel while someone else hits the shaft using a big punch and hammer. Be sure to leave the nut on however or you will go for a ride if the wheel breaks loose. Good Luck
This page was generated in 0.058 seconds.
