6080 radiator weeping
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: 6080 radiator weeping
    Posted: 03 Nov 2016 at 9:31pm
Howdy all,
Looks like I am starting to get some leaking in the bottom of my radiator right by the seam between the fins and the bottom tank.  I can't see where it is coming from, but it is getting wet, and getting worse.  Where should I start looking for a replacement.  Should I consider repair from a local shop?
Thanks for your advice.
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 10:01pm
That's the first step and if beyond repair have it recored.A decent shop will have quality supplier and you'll have a radiator that out lasts you.
PS don't whine about the cost
Edited by SteveM C/IL - 03 Nov 2016 at 10:02pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 10:25pm
6080's are pretty easy to pull the rad. Just take it to a shop to have it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 4:04am
They have to be custom made, just had one done at $550,,
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:44pm
Yep.  No replacements available aftermarket.  Best to get your rad re-cored.  Should be good for another 30 years.
