6080 Leaking at injectors - is it valve cover gask
2MaineFarmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2MaineFarmers Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Leaking at injectors - is it valve cover gask
    Posted: 03 Aug 2024 at 11:00am
This looks like injector seals to me, but it is oil and in reading up on the forum it looks like there are no injector seals? Does that mean it has to be a valve cover gasket? If it was diesel I would say banjo bolts but it's black. The thing is, it leaks while SITTING. I turned the tractor off, cleaned with brake cleaner, and came back to the pictures this morning. It's leaking at three of the 4 injectors and doesn't seem to be leaking around the valve cover itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2MaineFarmers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 11:02am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 12:48pm
In my experience, it's always the valve cover gasket. The oil seeps around the injectors and takes a long time to ooze back out. The injectors on a 6080 seal in a copper tube in the head. If the injectors weren't sealing in the tube, you would have a compression leak around the injectors. I suppose that there's a chance that the injector nozzle isn't sealing with the rest of the injector body, but I've never seen that or even heard of it. Replace the valve cover gasket and either replace the exhaust manifold gaskets or at least tighten up the bolts. I think that your leak will eventually dry up after doing this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2MaineFarmers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 8:07pm
thank you sir!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 6:41am
Pay attention when pulling valve cover bolt washers.  It’s a stack of multiple concave washers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 7:56am
In my experience , the valve cover bolts just loosen up ; retighten them and good to go ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 10:51am
Had the same issue on our 6060. Replaced the valve cover gasket and adjusted the valves while in there. Problem solved.
Edited by AC720Man - 04 Aug 2024 at 6:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 10:56am
The valve cover bolts shown in the picture were the latest design. The have a step, shoulder, that only let's the bolt go so tight. You tighten the bolts down completely until they stop and the little spring washers put a constant pressure on the gasket. Even if the gasket shrinks over time, the washers are still spring loaded and applying downward pressure. There should be 7 washers in each stack.
Edited by Lynn Marshall - 04 Aug 2024 at 10:58am
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 12:28pm
Also, make sure the lip on the valve cover is straight.
This page was generated in 0.087 seconds.
