6080 hydraulic prime
Ericinecmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ericinecmn Quote  Post ReplyReply Direct Link To This Post Topic: 6080 hydraulic prime
    Posted: 30 Dec 2016 at 8:06pm
Just changed hydro fluid in my 1983 6080 and both filters, filled the transmission and the rear end. My problem is it won't prime was working fine before just wanted to give it a little love and changed the fluid. This is my second time doing this and a don't recall this problem before. Any one have any thoughts on priming procedure?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 8:24pm
Do the filters screw on upside down? If they do I always fill the filter full of fluid before I screw them on. Fluid change on my dads 6060 went well, so I am not sure what the problem maybe other than air in the suction tube maybe. I think it should be self priming but I am sure someone on the forum will know.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:06pm
Common on 6080 if you don't fill both filters with oil, especially the one's with two filters.    MACK
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 8:56am
Far as I know there's no filter on the suction side of those tractor there's a screen down there in the block the safest thing to do is remove the pressure lines on the side of the pump use a vacuum cleaner to create a vacuum and pull the oil up into pump   start the motor with the Lines lose at pump. run tractor see if you get oil pressure shut it off and tighten lines up. Don't run tractor too long. Did you clean the screen on the suction side?
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ericinecmn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:49pm
Got it going this morning had to fill the filters twice and then it took. I topped it off and will let it sit for a day or so and make sure it does not lose it.
Thank you for the information
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:55pm
I have a new to me 6080. What brand filter did you use?
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ericinecmn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 11:36pm
I have been using Agco hydro filters mostly, but when I change engine oil mid season I pick up a Wix filter at the local Auto Value store
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2017 at 7:42am
Thanks.
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 2:47pm
Late to game, but this happened to me today.
Filled filter, and filled pump through one of the lines on the top (toward driver). Hopefully works tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 3:18pm
Prime the pump from the top and immediately start the tractor. Don't wait.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 4:04pm
Dr. Allis that is exactly what I did. Primed at the top, put everything back together, turned the wheel until flow through, cycled hydraulics, and everything works! Just wanted to post in case others search for this in the future.
Thanks all!
This page was generated in 0.362 seconds.
