6080 FWA
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 6080 FWA
    Posted: 07 Jan 2011 at 12:20pm
After thinking about making the 6080 into a puller, maybe I would trade to some one that wants to get rid of their pulling tractor and wants a 6080 FWA. The one that runs had a cab on it. It was taken off to restore the tractor, rear tires are not very good, fronts are toast. It runs good and steers good. It had some work done to the motor, but dont know what it was. The rearend housing has been welded, I am assuming it was from the PTO problem the had. The parts tractor has no motor and is an open station. I know the one with the cab all restored will bring 10-15 thousand up here, but it is a long way from there, and if I got serious about parting the other one then there is some cash there also. I am just to busy now that I have this new job running the states, to build another tractor The tractors I would be interested in are, unstyled WC, D19, D21, 190, 200, 210, 7000 series.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 4:05pm
Do you still have pto drive shaft in parts tractor?  I have a customer that bought a used 6080 and pto would not work and found the main pto drive shaft from the coupling to the rear pto housing was missing. Would you call me? cell # 706-816-8142  Thanks Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 8:57pm
Sam; I still have the parts tractor. What were the parts you needed. Give me the parts book page and part #s, and I will get you a price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 10:14am
Brian, page 212, item 23 #72092484 shaft, item 44 # 72092843 brg, item 45 # 72092845 brg. I looked these up on the Agco parts site.
thanks, Sam
