6080 Fuel Injector
rbaggett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Fuel Injector
    Posted: 24 Oct 2025 at 5:19pm
I have a 6080 that is leaking compression around one injector nozzle.  I pulled the injector but I don't see where the O ring goes.  I had a mechanic change the nozzles recently but this one nozzle is leaking.  Perhaps he failed to install o ring.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2025 at 6:00pm
There's no oring to seal compression, these use the tapered fit in the bottom of the copper tube in the head to seal. No washer of any kind is used in the bottom. Sounds like either your bolts are bottoming out not clamping it all the way down, or he put in washers that don't belong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2025 at 7:02pm
I don't like the sound of this.............
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2025 at 8:33pm
Yeah, better hope that the correct injectors were used and no additional parts were added to seal the injector to the copper tube. Otherwise, a head removal may be involved. Maybe just some dirt fell in the hole,which isn't good either.
