6080 brake fluid?
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 brake fluid?
    Posted: 24 Jul 2025 at 6:41pm
Book says 10w10. Found a quart of non detergent 10 weight oil at O’Reileys. Will this work? Thanks
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 8:40pm
Not saying that it won't work, but I would just use some regular hydraulic oil. Just don't use brake fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 8:20am
We always used ATF/Dexron and kept a couple of 1 quart jogs on the shelf just for 6000 series brakes.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 9:27am
It's a mineral oil brake fluid.  New Holland still sells it for around $20 a quart.  NH part number is 73340450.  LHM brake fluid is what it would be called in the automotive world.  I think some European car manufacturers used it for a while, like Citroen.  It's designed to use a mineral oil because if any bypasses the seals in the axles, it will mix with the hydraulic oil in the rear end without issue.  If you are losing a good amount of fluid, you may be due to replace the piston seals in the trumpets.
Hurst
1979 Allis Chalmers 7000
5800 Hours
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:27am
I think Massey used the same typ of mineral fluid in their tractors
1968 D15D,1962 D19D
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 4:12pm
Why did AC make this oddball? Fiat design?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 4:24pm
IM with the DR.. and OLDER type of trans fluid is 10w and would be good.. Not the NEW MERCON LV or Dextron 6.. ETC... Use the older stuff that is not synthetic and full of addatives, detergents.... Type A, F, Dextron 1-2, etc.
