6080 block update |
| Author | ||
Mikez
Topic: 6080 block updatePosted: 22 Dec 2016 at 11:15pm |
I remember seeing a post awhile back of the engine sr number of when they beefed up the inside thrust bearing inside 6080 motor. Was woundering if anybody still had that info. Thanks
| Sponsored Links | ||
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2434 |
Posted: 23 Dec 2016 at 8:44am |
hillmonkey
Joined: 03 Apr 2010 Location: oville fl Points: 417 |
Posted: 23 Dec 2016 at 10:05am |
Good info Lynn,I wonder what it would take to have that posted in "knowledge base"?
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 23 Dec 2016 at 10:15am |
Thanks for the copies Lynn. I always thought that later on in the production of the 433 block, it was beefed up internally to help with the thrust problem. It really wasnt a problem with the block its self. It was with what was behind it in the 6000 series.
Posted: 23 Dec 2016 at 11:43am |
The very late engines had a thrust bearing flange that was about double the width from the original design. Older blocks sometimes wouldn't accept the newer thrust bearing without machining the cap or upper bearing saddle sides. External thrust bearing was a good fix, but still requires some upkeep and maintenance.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8737 |
Posted: 23 Dec 2016 at 8:30pm |
You talking about the nut behind the wheel? |
ILGLEANER
Posted: 23 Dec 2016 at 11:59pm |
A lot of times yes !!!!! |
Mikez
Posted: 25 Dec 2016 at 10:42pm |
Thanks Lynn that's what I rememberd reading.
