6070 vs 6080
AC Nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Topic: 6070 vs 6080
    Posted: 16 Mar 2012 at 10:22am
Does anyone know of any problems with the 6070 model? I see one on Tractor house for cheap in Ohio. Are they as nice as the 6080?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 12:38pm
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6562547&
Here is the listing on Tractor house. Just wondering if anyone has had history with this model and your thoughts. Looking for a hay tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:31pm
Pretty much the same tractor , little less hp ; same tranny , i think they were manufactured the last 3 years of the 6000 series run , ???
Edited by DougG - 16 Mar 2012 at 6:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:32pm
Same tractor except smaller clutch and no intercooler and 73 HP instead of 83 HP.....rear tires sizes may be smaller and on pressed steel centers depending on how it was ordered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:00pm
This tractor was a ROPS tractor with a factory cab installed recently. Would that be a concern as far as electrical and other mechanical operation?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:12pm
Hey Nut, I saw that tractor too. I googled the phone number and saw he was looking for a door for the cab at one time...I wish it was closer I would go take a look.  I only need a 2wd tractor and this would be exactly what I could use, but kinda concerned that it hasn't sold by now at that price. Could be because it is 2wd and mfd is what everyone wants now????
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:39pm
I talked to the guy this afternoon and he said he overhauled the engine and new clutch. Seems like a nice tractor, but the cab thing  makes me wonder. I should have him check the serial # as might be one of the last Allis Chalmers tractors built!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:27pm
Did you ask him about the thrust bearing update?? Did he install AC?
ALLIS EXPRESS!
This year:
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:38pm
6070s were made in 1984 and 1985.  I think the thrust bearing issues were resolved by then.  Looks like factory ac compressor (with no cover).  Sounds like a pretty nice deal, especially if it is overhauled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:45am
It would bother me that it was overhauled.....they usually last 8 or 9,000 hrs before it's needed.
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 3:28pm
People talk about the thrust bearing problems on the 6060 and 6080 tractors. Was there a specific date or tractor serial number where this problem was fixed at the factory before the tractors were sold ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 7:23pm
Dunno bout the factory serial number thing , but i do know dealers put them on asap , per AC saying so
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 9:57am
the thrust bearing was a bigger issue in the 6080, than the 6060 because it had the heavier clutch, here is a listing i just found for a fwa 6060 that might be a good deal
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 10:45am
I wonder how those industrial rear tires match up to the new front tires as far as the 4x4 goes? They look kinda small....
ALLIS EXPRESS!
This year:
