6060 tractor starts then dies
chefiam1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Topic: 6060 tractor starts then dies
    Posted: 20 Sep 2019 at 9:41am
i have a 6060 tractor changed the fuel filter started ran 3 min then died
bleed all lines. fuel spitting from injectors. seems like it is running out of fuel.
    any ideas what could be wrong. plus it seems to be blowing alot of smoke.
Edited by chefiam1 - 20 Sep 2019 at 9:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 4:49pm
it was something between the gas tank and the filter. blew it out with air
so far so good.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 5:16pm
The shut off tee at the bottom of the tank have a habit of getting plugged or restricted.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 8:45pm
Loosen timing window on side of pump until fuel runs out. Crank it up and see if it runs OK until you tighten the screws.     MACK
This page was generated in 0.281 seconds.
