6060 spindles
Rafterg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rafterg Quote  Post ReplyReply Direct Link To This Post Topic: 6060 spindles
    Posted: 02 Apr 2024 at 2:14pm
Anyone have a source of heavier spindles for a 6060. Just broke my 3 spindle on the right side in two years.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 3:17pm
What are you lifting???
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 4:23pm
Rafterg, I don’t own a 6000 series tractor. So I’ll ask this question. Does your 6060’s steer cylinder push directly into its right spindle & then that spindle pivots its turning forces into a tie-rod which in turn pushes left spindle? If yes, then try relocating steer cylinder so it pushes directly into tie-rod; thus minimizing ALL its forces (energy) into the right spindle and somewhat equalizing its force between both spindles.
Edited by AC7060IL - 02 Apr 2024 at 5:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2024 at 5:59pm
Loader tractor I assume ???   Run less air in your front tires and drive slower. There are no "heavier" spindles available.
