6060 power steering problem |
chefiam1
Joined: 20 Sep 2019 Location: centerville,pa Points: 17 |
Topic: 6060 power steering problemPosted: 10 Jun 2021 at 11:38pm |
6060 power steering.
replaced the hand pump. but still does the same thing when i try to turn i have to keep on turning the steering wheel to make a easy turn. stumped! all help would be appreciated. thanks, chef
Posted: 11 Jun 2021 at 6:20am |
In 45 plus years, I have never changed out a steering orbitrol on any AC tractor. Rebuild your steering cylinder.
Edited by DrAllis - 11 Jun 2021 at 6:21am |
chefiam1
Posted: 11 Jun 2021 at 6:30am |
thanks i will look into cylinder rebuild
chef
CTuckerNWIL
Posted: 11 Jun 2021 at 9:45am |
Yep, cylinder is leaking past the piston. On my little utility tractor, I noticed if you drove very far in a straight line, you had to keep turning the steering wheel to the left to keep going straight. Put a kit in the steering cylinder and all is well.
Posted: 11 Jun 2021 at 9:58am |
That may be true on some tractors and not true on others. In the case of a 170-175-180-185-190-200-7000 etc, etc one end of the steering cylinder has more volume than the other, so when constantly turning the steering wheel back and forth (field use) the steering wheel usually gains to the clockwise. Nothing wrong. Just the way it is. Some tractors have a balanced system where the steer wheel might stay the same most of the time. Again, nothing to worry about as long as it drives well and turns well.
CTuckerNWIL
Posted: 11 Jun 2021 at 10:43pm |
I used to work for a guy that had a 170 diesel. if you drove straight down a road for a mile, you had to turn the wheel to the left nearly a full turn. I believe that was the same problem, oil leaking by the piston. |
Mikez
Posted: 11 Jun 2021 at 10:56pm |
had weird stuff going on with 6080 like that. Had steering cylinder seals done and fixed it
Posted: 12 Jun 2021 at 5:59am |
Normal. Unequal displacement between each end of the cylinder.
