6060 oil in radiator
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: 6060 oil in radiator
    Posted: 27 May 2023 at 2:15pm
Was getting ready for hay season only to discover that there’s oil in the radiator, no antifreeze in the motor. Drained the radiator into a bucket and let it separate, and it now has a thin layer of oil in it. Checked the oil cooler for pin holes but haven’t found one.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 5:34pm
Likely the oil cooler. So, why don't you disconnect the two water hoses to the oil cooler and plug them. Operate the tractor without the oil cooler connected to coolant for a while. I'll bet you'll see oil coming out of the coolant nipples on the cooler. Run engine at full throttle sitting still.
Edited by DrAllis - 27 May 2023 at 8:02pm
