6060 is which Fiat tractor? |
WNYBill
Topic: 6060 is which Fiat tractor?Posted: 02 Aug 2016 at 6:51am |
The 6060, 70 and 80 are the same Fiat tractors with an Allis engine, is there a Fiat branded tractor that is identical? Probably would have a Fiat engine. Might be a simpler source of parts.
Bill
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 02 Aug 2016 at 7:17am |
The rear end was Fiat (transmission back), that was it.
Never heard what that went to. I guess you could search Fiat models of the late 70's/early 80's and match them up.
Charlie
Charlie175
Posted: 02 Aug 2016 at 7:24am |
Maybe a Fiat 880? (I think that matches a 6080)
Charlie
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 02 Aug 2016 at 11:12am |
Heston 890 sort of.
Acmike
Posted: 02 Aug 2016 at 1:06pm |
there are other differences although they may use some of the same parts things like gear ratios are different,found out the hard way.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |
Posted: 02 Aug 2016 at 5:08pm |
6060 Used trans and rear end from a Fiat 780. 6080 used trans and rear end from a Fiat 980. I think there are more 6000 AC tractors in North America than Fiats! However, Fiat has also supplied other manufacturers with drive train components as well. The best place to start looking for parts is your local AGCO dealer (although mine is 2 hours away from home).
