6060 FWA |
| Author | |||
MJ79
Topic: 6060 FWAPosted: 26 Oct 2021 at 9:19pm |
Hello, all.
Anyone know where I may find a driveshaft for the FWA on a 6060? I’ve browsed many websites with no luck. I’m sure salvage yards may have one, but don’t know of any moderately close to Cheyenne, WY. Thanks! 07B89357-CA6B-4483-88B0-DDADA1CBF84F.jpeg |
| Sponsored Links | |||
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2884 |
Posted: 27 Oct 2021 at 6:10am |
First call I’d make is All States Ag Parts in Salem SD, never know Worthington Ag might have one. Summerix is worth a try also but Ivan isn’t cheap. Cook’s in Illinois or Missouri has a reputation for decent Allis inventory. I have very bad taste in my mouth for Heitman.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12383 |
Posted: 27 Oct 2021 at 7:05am |
Mark Heitman treated me perfectly when I needed him. Experiences vary, so he may be worth a try for you.
MJ79
Posted: 27 Oct 2021 at 8:23pm |
Thanks for the recommendations. I think I’ve searched most of the websites mentioned. Called Wenger’s but the part they has listed was not the shaft I need. May have to call to see if they have parts not listed. Is it the same as 6070 & 6080? May inquire at a fabrication shop to see if they can make it.
Alvin M
Posted: 28 Oct 2021 at 5:31am |
Did you check Countryside tractor in PA 717-923--0421
Tbone95
Posted: 28 Oct 2021 at 6:20am |
Wilson Farms in Bellville, OH?
victoryallis
Posted: 28 Oct 2021 at 6:27am |
Bought a tractor from him went to load it on my trailer rear end was out only moved by fwa. Got it home found out the PTO shaft was broke off internally in two places and bolts on the oil pan were only finger tight. Check cleared the bank zero willingness to make it right. I’ve spent twice what I paid for it fixing and it still needs a motor. He should have sold the “sheet metal” as salvage and put the rest in a scrap trailer.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2589 |
Posted: 28 Oct 2021 at 10:38am |
heres the link to a guy on facebook that has a 6080 parts tractor not sure if the shafts the same.
Edited by Acdiesel - 28 Oct 2021 at 10:38am |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Tbone95
Posted: 28 Oct 2021 at 5:43pm |
What do you want me to say? I believe you. More/less remember your story. Yet, that’s exactly what he did for me, did right by me. Experiences vary. 🤷♂️ Having said that, if I bought a tractor that wouldn’t drive up the trailer in 2wd, I wouldn’t have bought it and loaded it until I knew what was wrong. Edited by Tbone95 - 28 Oct 2021 at 5:45pm |
victoryallis
Posted: 01 Nov 2021 at 11:31am |
Not to mention I’ve used the tractor daily for 3 years and hour meter hasn’t moved.
PeteMN
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 208 |
Posted: 01 Nov 2021 at 12:23pm |
Buy a 12v hour meter and wire it in to the key switch.
victoryallis
Posted: 01 Nov 2021 at 3:37pm |
How does that play into buying a tractor with only xxxx hours on it? |
heitmantractorsalvag
Posted: 03 Nov 2021 at 8:20am |
Hopefully this brings closure to this thread. Victory Allis (Thomas Grabowski) came, drove the tractor and purchased as is knowing the tractor had a bad rear end (see receipt below). Heitman Tractor Salvage does not pressure anyone into purchasing any equipment that they are unsure of. If he was unsure of the tractor, he should not have purchased it. It's that simple.
Tbone95
Posted: 03 Nov 2021 at 10:46am |
So there's the other side of that story!
victoryallis
Posted: 03 Nov 2021 at 12:56pm |
Receipt is dated May 29th I was not in Wisconsin until JUNE 27th and had not drove it till the evening of JUNE 27th. The receipt proves you knew the rear end was out. Tractor was bought site unseen based off you description. I’m not new to the fixer upper tractor gig either that 6080 was number 3 out of 4. The guy I bought my 8050 from ended up becoming a good friend and we text back and forth 4-5 times a week.
Michael V (NM)
Posted: 03 Nov 2021 at 2:26pm |
How bout a local machine shop building one??
