|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 6060 Dropped RPMs |
| Post Reply   |
| Author | ||
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Topic: 6060 Dropped RPMs Posted: 26 Jun 2017 at 7:19pm | |
   This morning was going to bush hog some acreage. The fuel tank was below half so I topped it off and started. After about 30 minutes it lost power and would not run over 1600 rpms. I took it to barn, changed fuel filter. No help. Drained about 3 gallon from fuel tank, no water, pretty red fuel. Disconnected fuel line at filter and blew air back thru tank. No help. Runs smooth at 1600 rpms for about 3 minutes then starts running rough for a little while then quits. Is the fuel pump built into the injector pump? Could the injector pump be the problem???? Thanks in advance for the help!! | ||
     Allis Chalmers 6060 10' Howse Rotary Cutter 5' Tiller 5' Box Blade 4' Aerator Ferris Zero Turn Mower W/10' fold up sprayer John Deere 455 Lawn Tractor John Deere 955 w/loader & 60" belly mower | ||
| Sponsored Links | ||
| SteveM C/IL   Orange Level Access   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |  Post Options  Thanks(0)  Quote  Reply  Posted: 26 Jun 2017 at 8:45pm | |
governor flex ring coming apart and plugging return....
| AC720Man   Orange Level     Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5249 |  Post Options  Thanks(0)  Quote  Reply  Posted: 26 Jun 2017 at 8:46pm | |
   Dads 6060 did nearly the same thing. Surging and also puffing white smoke. Had the pump rebuilt and it resolved the problem.
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 26 Jun 2017 at 9:49pm | |
 Is this in the injector pump? | ||
| kinghunter   Silver Level     Joined: 30 Jan 2010 Location: Kansas/Missouri Points: 408 |  Post Options  Thanks(0)  Quote  Reply  Posted: 26 Jun 2017 at 10:34pm | |
   Yes time for pump rebuild | ||
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2017 at 2:51am | |
   Is there a link that tells how to make sure it's timed before removal of the pump or can someone tell me how to do it? Edited by Eddie - 27 Jun 2017 at 6:44am | ||
| injpumpEd   Orange Level Access     Joined: 13 Sep 2009 Location: Walnut IL Points: 5121 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2017 at 7:50am | |
   simply take the timing cover off the pump by the nametag, turn the engine by hand until the 2 lines match up with each other. Then it's just a matter of disconnecting lines and linkage, and the wire. Shaft can stay in the engine. Upon re-installation, look at where the engine is positioned, so you can correct any minor timing errors. It may have been off a degree or 2.
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2017 at 8:03pm | |
   Thanks everyone, found someone to rebuild it. Now just to get it off and get it to him!!! | ||
| AC720Man   Orange Level     Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5249 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2017 at 8:19pm | |
   Ed was your best bet to rebuild it...trust me, he is really good.
| AllisFreak MN   Orange Level Access     Joined: 07 Dec 2009 Location: Minnesota Points: 1589 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2017 at 9:33pm | |
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Jul 2017 at 9:10pm | |
   Picked it up from the re-builder this afternoon. He said that the flex ring was the problem and that I should blow out the return line with air before reinstalling the pump. Should get it installed tomorrow morning!!! | ||
| SteveM C/IL   Orange Level Access   Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8678 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Jul 2017 at 10:49pm | |
Once you get it all bolted up,back engine up 1/4-1/2 turn then rotate fwd till correct degrees at pointer,then see if marks in pump are in line.May need a tweak.
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 04 Jul 2017 at 3:16pm | |
   Got it reinstalled all lines tight, alternator back on but ran out of gas before trying to start it. Not in the tractor, but me. When your 72 with Afib you don't have a lot of gas. Will get it started tomorrow!!! | ||
| LeonR2013   Orange Level     Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |  Post Options  Thanks(0)  Quote  Reply  Posted: 04 Jul 2017 at 7:43pm | |
   Eddie it looks like you need to join Dale and I on the front porch and watch the world go by.
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 05 Jul 2017 at 12:31pm | |
   Leon, I frequently have to do some "major mechanic work." Putting a rear end in a recliner!!!! Got it running and bush hogged about 8 acres before I got rained out!! | ||
| AC720Man   Orange Level     Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5249 |  Post Options  Thanks(0)  Quote  Reply  Posted: 06 Jul 2017 at 9:11pm | |
   How did she run? We also noticed a little more power after the pump rebuild. The power in my XT was even more drastic, turned it into a totally different tractor. Obviously for the best.
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Jul 2017 at 6:19am | |
   It runs great!! I thought more power, then I thought just my imagination. But maybe it was. I was pulling 10' bush hog in some really heavy grass and weeds. | ||
| victoryallis   Orange Level   Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Jul 2017 at 9:03am | |
 Trying to kill him? Seen it too many times folks stop being active they go downhill fast. I'm not the only to make that observation. | ||
| Tbone95   Orange Level Access     Joined: 31 Aug 2012 Location: Michigan Points: 12246 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Jul 2017 at 9:31am | |
 I'll second that observation. I get so pissed at my sister and my niece telling my dad he needs to stop doing stuff.  My niece, his granddaughter, literally replies with "what good are you going to do trying to do that?!"  Pretty soon, you here him saying, "I'm not much good anymore."  Breaks my heart.  I try to do things I think he could get hurt at or hinder me unnecessarily quietly by myself...if he offers, I usually let him, or if he says "I could have helped you", I'll say I thought you were busy with something else.  I hate to see him in severe pain as much as the rest of the family.  But have him truly stop doing everything, then see what happens! | ||
| Eddie   Silver Level     Joined: 25 Nov 2010 Location: North Alabama Points: 117 |  Post Options  Thanks(0)  Quote  Reply  Posted: 07 Jul 2017 at 12:01pm | |
   I ain't gonna quit!! I just have to rest often, can't do any heavy physical labor, Son is a Nurse, won't let me get on a ladder even to change a light bulb. But I try to keep things to do. Who ever said getting old was fun had to be about 30!!!!!!! | ||
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
