6060 Circuit Board Assembly Failure |
Post Reply |
Carl Myrtle Point
Bronze Level Joined: 01 Dec 2020 Location: Myrtle Point, o Points: 32 |
Posted: 20 Jan 2021 at 12:57am |
None of lights (alternator, turn signals, eng. oil. pressure, hand brake, brake oil level, PTO disengaged, air filter) work on the Circuit Board Assembly. Before I try to track down this part #0258677-4 in hopes that this fixes the problem, I was wondering if anyone had any experience with this problem and any luck fixing it. Thanks in advance. Carl
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21462 |
wild guess.... is there a separate fuse that powers that board of lights ?? have you a wiring diagram ??
Orange Level Access Joined: 12 Sep 2009 Points: 19504 |
Well, there's 6 or 8 light bulbs behind that face screen. Maybe your bulbs are burned out.
MACK
sounds like you may not have current or a ground to board. Usually when one goes bad, it is one light. MACk
Alvin M
Orange Level Joined: 24 Jun 2018 Location: PA Points: 728 |
Pull wire connecter on circuit board check wire ends they can be replaced
Carl Myrtle Point
Thanks, I appreciate your suggestion. carl |
Carl Myrtle Point
Thanks for your reply. Right up front, wiring/ electrical is not my strong suit. Looking at the wiring diagram it does not appear that the assembly has a separate fuse. Both the tach/hour meter and the fuel/water temp gauges work. It does show a diode behind the dash that may have failed. Attached to the wiring harness connector that goes into the circuit board assembly there is a wire called "TERMINAL, P.C. connector (to replace broken terminals in the panel-to-harness circuit board connector)". I take it from that they anticipate that something may need to be replaced someday! Thanks again - carl
Carl Myrtle Point
Thanks Mack, Right up front, wiring/ electrical is not my
strong suit. Both the tach/hour meter and the
board connector)". I'll have to track down the wires going into circuit board assembly and see as you suggested I am not grounded or have no power going in. thanks again - carl
Carl Myrtle Point
Thanks Doc, it did not occur to me that it might be that simple since none of them work but you may be right. As you can probably tell wiring/ electrical is not my
strong suit. I'll have buy a box of bulbs. Both the tach/hour meter and the
board connector)". That tells me that the engineers anticipated some sort of failure sooner or later. thanks again - carl
LB0442
Orange Level Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
This is the wiring diagram I have. You can copy it to your computer and blow it up better. It shows it gets power from the fuel/temp gauge so if that is working check to see if the red wire is in good shape from there to the connector on the board. I use a simple test light to check these. Looks like the ground for it goes over to the fuel/temp also. When you take the top panel off of the dash it is fairly easy access.
Do the easy stuff first like bulbs/connections, good recommendations here.
Carl Myrtle Point
Thanks for all the good information. It downloaded and printed just fine. I'm looking forward to working on it. My current project is transferring a 460 loader from a 6080 to my 6060. Then I am going to sell the 6080. This area in SW Coastal Oregon is not big Allis Chalmers country so we will see how long it takes. Again I really appreciate all the time you took to share this information. carl
Post Reply | |
