6060 cab leaks water
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Topic: 6060 cab leaks water
    Posted: 27 Sep 2016 at 7:17pm
looking for advice on sealing up leaking access panel on top of cab , tractor sat outside for first time in years and leaked like seiv . took panel off top of cab, gasket kinda old not super bad, some washers under bolts squashed and smashed but all there should I replace seal w oem or other material I wll replace washers under bolts.would it b good idea to put silicone bead around outside after bolted on
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 7:35pm
I just used clear silicone then bolted roof down squishing it.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 7:38pm
if your a/c drain hoses are plugged, it will rain on you in the cab too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 7:42pm
Haha yup been through that too shameless
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 8:41pm
AGCO carries the gasket and individual rubber washers as a kit.
sherman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sherman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 8:12am
I have used 3/4x1/2" house weather striping as a seal around the panel and it works well if you clean down to metal and paint before applying.
for the bolts I used new washers and out of a innertube I cut out rubber washers to go underneath the flat washers. no leaks even in very heavy rain. silicone would work but not for the long term. you have to get up there to blow out your evaporator every 6 months...
I did one like this 10 years ago and it still is tight.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 4:03pm
Check your A/C drain hoses.  Yes, they will leak into the cab and make you miserable.  Looks like you have enough good advice here already.  Good luck.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 4:35pm
Yup check that drain hose on a cold morning. Typically it will be a mud wasp has moved into the hose guess it is a perfect place for them to make a home. But you don't want to find that out by blowing in the hose and getting a wasp in your mouth.
This page was generated in 0.071 seconds.
