6060 brake repair questions; DOT 3 fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6060 brake repair questions; DOT 3 fluid
    Posted: 01 Mar 2010 at 6:35pm
Got a 6060 AC that someone put DOT 3 brake fluid in the reservoir; now it leaks out, Ive heard the DOT fluid will eat the seals up ; Im guessing this is a total tear down ; with the final drives coming off to get to the brakes ; question is ; will there be any machine work to get any surfaces back to true ? Ive never had one apart , but dont look to bad ; any quick fixes ? I took the master cylinder apart, cleaned it up, new -O- rings ;all looks good; any pointers to this job !!! Thanks !!!!
