6060 Allis Chalmers Oil Filter Base Mount
Ccreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ccreek Quote  Post ReplyReply Direct Link To This Post Topic: 6060 Allis Chalmers Oil Filter Base Mount
    Posted: 23 Jun 2018 at 12:58pm
Can someone help me with the parts number for a 6060 Allis Chalmers Oil Filter Base Mount and where I might be able to locate this part.  Any help will be much appreciated.Confused
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 1:22pm
You can access the AGCO parts books at www.AgcoPartsBooks.com and sign in as a guest user. Enter 6060 in the model box and select AGCO Allis in the Brands drop down box. You can see the different filter bases along with related parts and get the part numbers for the filter you are looking for (engine oil, fuel, or hydraulic).
Your AGCO dealer maybe able to get what you need. Someone else on here will likely join in with other options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ccreek Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 1:53pm
Thanks so much.  I think I might have found the parts number I need.  I was calling it the wrong name when searching.  The parts diagram was most helpful.  I appreciate the help.Smile
