6060 3pt lift
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Topic: 6060 3pt lift
    Posted: 16 Apr 2012 at 5:00pm
Is there any way to slow the 6060 3pt hitch down when it's lifting. When running at working RPM's it lift's so fast and hard that it jerks the whole tractor. When running at idle it works smooth. Seems like there should be a way to turn the pressure down a little.
Edited by Eddie - 16 Apr 2012 at 5:06pm
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:54pm
I know what you mean, mine is the same way.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:17pm
Yes there is an adjustment knob that controls the lift speed.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:21pm
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79005852
Lift Shaft Sensitivity Control (Item 236)
Edited by Charlie175 - 16 Apr 2012 at 7:22pm
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:29pm
Charlie, can't get the link to work. May be my problem
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:17am
It is located on the right side behind the lift control levers on the floor.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 8:29am
I move that up and down and it doesn't change anything, I'm assuming you're talking the knob in the floor on the opposite side of the seat from the PTO gear knob.
Edited by Eddie - 17 Apr 2012 at 8:30am
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 11:16am
Yes that is supposed to control the sensitivity of the 3 PT. Maybe check the linkage?
Charlie
