#60 All-Crop Harvester Attchments!!!
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: #60 All-Crop Harvester Attchments!!!
    Posted: 23 Sep 2012 at 11:07pm
 I wanted to post a few pictures of the attachments. Awhile back there was a posting that was not correct about dual wheels.
 First few will be the duals. When one would order duals they would receive 1 extended driver shaft and 1 extended driven shaft for pick-up reel & 2 deep disced rims.
 To mount the duals you need to remove every other lug bolt leaving the standard rims & tires on. Then use same bolts to mount the dual rim.
 Below shows the auger extention, no problem unloading into a 200 bu. wagon. Also the Scour-Kleen Unit.
 The six bat reel was also an option on the #60.
The next few are of the pick-up.
This one is a working picture so it's hard to see the straw spreader.
 The last is the clean grain conveyor screen.
 I do have the straw windrower but I have not taken any pictures yet.
Hope all enjoy.
Thanks & God Bless
Dennis
Horsepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Horsepower Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:06am
Great photos.  How much additional length was added to the auger?
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:18am
The auger extension is a good thing - mine could use that. -- see you have the canvas on the straw hood- did you make that or were you able to find one?  That is one nice machine you have there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:30am
Shoot, I was hoping to see a 2 row corn headLOL Looks like a good one though!
Edited by CTuckerNWIL - 24 Sep 2012 at 7:32am
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:32am
Very well done.  Thanks for sharing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:36am
What is the gear and chain on the outside dual wheel? Does that run the straw spreader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:38am
Pat, that runs the reel on the head, makes it follow ground speed instead of PTO speed.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 9:21am
I have the extended reel drive shaft/sprocket on mine but no dual wheel nor discharge auger extension. Think'in the auger extension would be handy! Those shaft extensions are easy to knock off.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 9:34am
Nice pics,
Would love to get my hands on a high header lift so as to make new ones....
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 11:33am
Thanks for sharing the photos! Very interesting.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 6:08pm
Good stuff Dennis.  Thanks for posting!
Jim
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:00pm
Great photos!!! Keep it up. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:15pm
  It's about 28".  From the auger to the ground is 9-1/2".
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:20pm
 I had a tent & awning shop make the curtain & weed seed bag for the Scour -Kleen.
Thanks & God Bless
Dennis
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:26pm
I still had this picture of a two-row corn head on an all-crop
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:45pm
     Never seen any duals like that. We had a 60 bagger and the wheels were offset. I have a neighbor that has a 60 with duals, and they are offset. I'll have to go get them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:48pm
 Sounds like the #60 bagger had the tandem wheel option.
Edited by DennisA (IL) - 24 Sep 2012 at 8:59pm
Thanks & God Bless
Dennis
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 10:24pm
   The cornhead was not introduced until after the 66 came out. Any 60 that is equipped with a cornhead was converted with a cornhead made for the 66's.
   The dual wheels and the tandem wheel setup are two different options as Dennis mentioned.
http://www.rumelyallis.com
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 3:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 3:06pm
here was one i made so we could put our organic wheat right into bags to sell had an auger that was beat up that i shortened to do this with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 3:21pm
this was a sad day when i sold that 66 allcrop i rebuilt on an auction for $125 due to family circumstances back in 2009 had all 4 combines there including the 3 parts machines and pallets of parts i always wondered were it ended up. Oh well time moves on
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 3:33pm
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 7:40am
Here are pictures of a AC 60 with duals.
Hope that helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 7:49am
I should know this...but what was the purpose of tandem wheels vs offset dual wheels?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2013 at 8:51am
I would think the tandom wheels would keep a more consistant cutting height because if you hit a hump the whole machine wouldn't raise up. The wheels would just walk over it. They might do a little better in wet ground since they wouldn't be so close together.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 5:36pm
Could an auger extension be made? I have an extra auger in the barn.
SC Dan K. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SC Dan K. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 6:08pm
Years ago my best friend had a row of all crops along his fence row for parts. He wanted an axle to build something else so we flipped one over and cut the axle out. Didn't realize we got through building the new project it had different rims than anything we've ever seen. They were extra deep dish and looked like you could mount two more rims on the outside of them. Unfortunately the bushings were worn and unavailable and the bolt holes started to crack. Wish I'd known more about dual wheels then
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 12:12am
Allis Dave you are right about the off set axles riding better. In fact you could go cross ways across the rows and not hardly shake the machine at all. Made it easy too combine level and close to ground. Ran one a lot behind a WD and for the time it was a fine piece of equipment. Did clean work too.
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 1:49pm
Rfdeere the cornheads fit the A series 60's and the later 60's. The duals were for sandy soils. I make the hood curtains for mine.i have most of the attachments for the all crop Combines.
Edited by combinechris - 18 Jun 2016 at 1:50pm
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
