6 volt question
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: 6 volt question
    Posted: 2 hours 59 minutes ago at 6:02pm
If a 12 volt battery is used to turn over a 6 volt car engine will it fry all the 6 volt bulbs fuses, etc? Thanks
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 29 minutes ago at 6:32pm
12 volt battery used on 6 volt bulbs would be brighter and burn out sooner then with a 6 volt battery.
Voltage reducers, 12 v. to 6 v., will be necessary to prevent 6 volt gauges, wipers, radios and accessories from overload.
Fuses don't care about the voltage, it is the amps.
