6 volt LED bulbs?
Message Reverse Sort Order
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: 6 volt LED bulbs?
    Posted: 29 Jun 2019 at 9:58pm
I am interested in hearing how it works out! May need to order some myself.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 7:00pm
I ordered them. Will report back.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 5:52pm
The 1133 white LEDs as posted by DennisA above work fine in any  6 Volt system,either + or - ground, they are what you want, just plug and play!!!  Pay no attention to the other posts above, they do not apply to this situation!!!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 2:25pm
LED bulbs are POLARITY sensitive - so you need + or -- ground bulbs . They just don't work without proper polarity . Seems I found out with British motorcycles as they are + ground .
 You can find bulbs on AMAZON that will work
Edited by Coke-in-MN - 24 Jun 2019 at 2:26pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 2:17pm
Make sure your flasher will work with LED's. My sheriff's department got this wild hair that they wanted LED's for their tail and directional lights. Net result: They wouldn't flash unless we installed resistors in parallel with the bulbs. The current draw was too low to perk the flasher. Finding a LED flasher for a 2014 vehicle was next to impossible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 1:30pm
I ordered what DennisA IL suggested. Will report back when they come in and I get them installed.Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 9:51am
Finding something for 6 volts will not be easy. There are LED's out there that can be made to work on 6 volts, but finding a plug and play one might be a problem, at least finding one with 50 equivalent watts or more. Look around. Google. I might be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 9:44am
Looking for a complete plug and play bulb.Just twist it into the socket and go. Dont want to do any wiring or resistors, etc. Keep it simple
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 8:19pm
Try these: https://www.digikey.com/products/en?keywords=CL25N3-G-ND
will operate on 5 to 90VDC, and output .025mA. They are also available in .010mA, .020mA, in both the TO-92 package, as well as SMD.
Edited by bigal121892 - 24 Jun 2019 at 9:00pm
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 8:06pm
wow learned more new stuff
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 6:43pm
You can’t merely string 2, 3, or whatever LEDs together to get to a12 volt total. You need a current limiting resistor, regardless of the voltage. In the case of using 6 volts for a 12 volt light, you would need to change the value of the resistor. It’s a little more complicated than just installing a resistor of half the value. You tell me the voltage and current rating of each LED and I can calculate the size of the resistor needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 6:24pm
White LEDs are actually about 3 volts, so 2 are in series to make 6 volts, 4 for 12. Depending on make/model of LED though some use 3 in series for 12 and a small resistor to limit current. Those good for 6-20 volts probably are run in 'constant current' mode which is how LEDs are supposed to be used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 6:16pm
I sure did not know they make 6v led bulbs.  Learn something new every day.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 11:26am
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 11:01am
Got my hayride wagon finished. Wired up some LED flashing warning lights for safety. Need to upgrade the lights on the WD45 now. Anybody know of any plug and play replacement bulbs? I have 6v GE1133 right now. Anyone have any experience with this? Thanks in advance!
