6 cylinder WD ad |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1289 |
Topic: 6 cylinder WD adPosted: 21 Dec 2010 at 9:00am |
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 21 Dec 2010 at 9:10am |
Too much paint, looks like a drive by shooting. I'd pass on that one just because of the paint job.
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 21 Dec 2010 at 12:22pm |
Yeah a bad paint job is just a PITA if you want to restore it... |
ALLIS EXPRESS!
This year: |
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Posted: 21 Dec 2010 at 12:32pm |
in desperate need of a sand blaster.
German Shepherd dad
Gary in da UP
Posted: 21 Dec 2010 at 12:49pm |
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 21 Dec 2010 at 1:11pm |
Is that a 292 chevy? I can't tell what kind of engine it is from the photos. Also, does it look like the frame has been lengthened? If did they just cram that engine into the 4cyl engine's spot? Something just doesn't look quite right.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 21 Dec 2010 at 1:12pm |
I'll bet they painted the tractor in one piece, sheet metal, wheels and all.
Claus
Posted: 21 Dec 2010 at 1:15pm |
Also, I would have expected it to look like a 45 diesel, what did they do cut and add to the frame rails? The steering box is still out front of the grille so something is wrong.
Sorry Hurst, I first missed your post. You and I are thinking along the same lines. Edited by Claus - 21 Dec 2010 at 1:16pm |
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 21 Dec 2010 at 2:20pm |
Got the D hood and guage cluster.Probably didnt know the frame lenght was the same and spliced in.Not a Chevy,manifold wrong side.Manifold looks wrong for a 230-262 gas. If he thinks it's that valuable,he should keep it.
Karl in MD
Joined: 04 Nov 2009 Location: Pocomoke, MD Points: 97 |
Posted: 22 Dec 2010 at 8:27am |
I looks a lot like a Continental, possibly even from an early Oliver 70. Maybe a "3 gear" from a Hart Parr 70. Hard to tell under those 20 gallons of krylon road-hazard orange.
A man's got to know his limitations.
'51 WD, Roto-Baler,, A-C rake, '44 C, '42 B |
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 22 Dec 2010 at 9:38am |
This tractor is only 30 miles from me. It is owned by a Junk yard so I am assuming it is not a real top notch job. I believe the frame was extended. he also has a WC for sale with really fresh paint on it.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34437 |
Posted: 22 Dec 2010 at 10:02am |
continetol or hercules motor the way the manifold looks.
Fenders are cut off and can anyone see the bat box?
Bet the grease, rust and old paint is still under the slap and dab job.
Chris (swIA)
Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
Posted: 22 Dec 2010 at 10:05am |
Paint, goofy engine conversion, bug eye headlights. even the wide front looks like it had a plate welded across the frame rails to hold it together. if there was every one not to save, this would be it.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6109 |
Posted: 22 Dec 2010 at 7:17pm |
Can't tell for certain from details other than the manifold and carb location, but it LOOKS like it might be a Hercules JXLD, or one of the slightly smaller ones. If so, well, that's a heckuva horse... 331ci long-stroke six... a true industrial brute... but flathead, rather than valve-in-head, and quite a bit heavier than an AC engine.
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 22 Dec 2010 at 7:24pm |
I've never seen a tractor painted with a paintball gun before.
are genuine." - Mark Twain |
Gary in da UP
Posted: 22 Dec 2010 at 7:37pm |
So, from the comments made , we could agree this is a RARE tractor ?
MACK
Posted: 22 Dec 2010 at 9:40pm |
The manifold looks like the old 230 buda like the old A gleaner or co-op. MACK
DaveKamp
Posted: 23 Dec 2010 at 9:14am |
Rare, from the definition of being 'incomplete in finishing, or undercooked'...
Gary in da UP
Posted: 23 Dec 2010 at 9:26am |
Dave, I like your definition.
