6 Bolt Hub D17 Series 2 |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Topic: 6 Bolt Hub D17 Series 2Posted: 28 Mar 2026 at 6:38am |
What does it take to put 6 bolt hubs on the front of a D17 Series 2? From the 6 times I've read the parts book all the bearings and cones are the same. The only difference is the hub cap and seal. I always thought one bearing was different and guys on Facebook are telling me the same, but the parts book doesn't back that up. AaronSEIA
Posted: 28 Mar 2026 at 7:44am |
It's been too many years ago, but I believe it was always the (larger) inner bearing and cup that were different. The outer bearing/cup remained the same. The six bolt hub design was for more weight carrying capacity. Use the series 4 parts book and then a 170 parts book ( 6-bolt only) and you'll kind of see that. On that larger inside bearing they listed two different bearing cones ( 70047751 and 70209899), but only one cup. I don't know why. Maybe one number was discontinued and it subs up to the other number ?? I also see the original 6 bolt hub was 70236706 and then the later was 70261418. I think old was a screw on cap and the later was a drive on cap.
AaronSEIA
Posted: 28 Mar 2026 at 10:02am |
Interesting. The Series 4 parts book lists the following numbers: hub 70261418 outer cup 70209983 outer cone 70209926 inner cup 70209987 inner cone 70222214 Oddly that hub number calls for a drive on cap but the aftermarket world seems to have threaded it for the screw on one. All those part numbers are the same for the 5 bolt hub. AaronSEIA |
Posted: 28 Mar 2026 at 3:36pm |
I'm thinking now the spindle diameter is different as the series 4 has two p/n's for the WF spindles at a very late serial number. 70236706/70261418 are the 6 bolt hubs. 70237438 is the 5 bolt hub. 70209899 should be the inner cone and 70235089 should be the cup for 6-bolt hubs. Part numbers change over the decades and sometimes they do get entered into the on-line parts system. Sometimes not.
Edited by DrAllis - 28 Mar 2026 at 3:45pm |
VaAllis1990
Joined: 26 Jan 2022 Location: Champlain Va Points: 34 |
Posted: 29 Mar 2026 at 8:35am |
Per my original parts book, outer bearing and cone are same for 5 and 6 bolt hubs.
Inner cup is specific to the hub, inner bearing is specific to hub AND front end Inner bearing: 5 bolt- 222214 6 bolt roll shift front- 209899 6 bolt dual front wheel- 4254794 Inner cup: 5 bolt- 209987 6 bolt- 235089 Outer bearing: 209926 Outer cup: 209983 Also, on a narrow front, the bearing spacer has a different OD depending on felt or rubber wheel seal |
Joined: 11 Sep 2009 Location: illinois Points: 90778 |
Posted: 29 Mar 2026 at 8:53am |
I dont know the specific bearing listed.. but if you had a spindle and a hub, and you wanted to Increase Capacity... you can buy a bearing with the SAME ID that fits the spindle and a LARGER OD for a NEW HUB, and the larger bearing would have a greater load carrying capacity most of the time... Use the ORIGINAL SPINDLE ...Normally itis not the SPINDLE that is the limiting factor.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4273 |
Posted: 22 hours 15 minutes ago at 6:41am |
When I put 6-bolt hubs, (from a hundred series tractor) on my 45, had to get series 4 D-17 spindles to make it work. I have a feeling you are headed down a similar road. You will need the steering arms to go with them most likely.
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 20 hours 23 minutes ago at 8:33am |
Do like Steve above says. Find a good auto parts or bearing store and buy the cups and cones separately. We put 6 hole hubs on my dad's series 1 D17 back in the 80's because he was breaking the center out of the 5 hole rims moving round bales
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 6 hours 22 minutes ago at 10:34pm |
I put an 8000 series hub on my 220. The inner brg and seal were different but the hub was identical. Think the 8000 used thinner cup and larger bore cone. Something like that....
