6 Bolt Hub D17 Series 2
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: 6 Bolt Hub D17 Series 2
    Posted: 9 hours 7 minutes ago at 6:38am
What does it take to put 6 bolt hubs on the front of a D17 Series 2?  From the 6 times I've read the parts book all the bearings and cones are the same.  The only difference is the hub cap and seal.  I always thought one bearing was different and guys on Facebook are telling me the same, but the parts book doesn't back that up.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 1 minutes ago at 7:44am
It's been too many years ago, but I believe it was always the (larger) inner bearing and cup that were different. The outer bearing/cup remained the same. The six bolt hub design was for more weight carrying capacity. Use the series 4 parts book and then a 170 parts book ( 6-bolt only) and you'll kind of see that. On that larger inside bearing they listed two different bearing cones ( 70047751 and 70209899), but only one cup. I don't know why. Maybe one number was discontinued and it subs up to the other number ??  I also see the original 6 bolt hub was 70236706 and then the later was 70261418. I think old was a screw on cap and the later was a drive on cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 43 minutes ago at 10:02am
Interesting.  The Series 4 parts book lists the following numbers:
hub 70261418
outer cup 70209983
outer cone 70209926
inner cup 70209987
inner cone 70222214
Oddly that hub number calls for a drive on cap but the aftermarket world seems to have threaded it for the screw on one.
All those part numbers are the same for the 5 bolt hub.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 minutes ago at 3:36pm
70236706/70261418 are the 6 bolt hubs. 70237438 is the 5 bolt hub.  70209899 should be the inner cone and 70235089 should be the cup for 6-bolt hubs. Part numbers change over the decades and sometimes they do get entered into the on-line parts system. Sometimes not.
Edited by DrAllis - 6 minutes ago at 3:39pm
