5hp scamp engine problems
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: 5hp scamp engine problems
    Posted: 29 Oct 2017 at 11:45am
Our B&S 5 hp engine on our Scamp is smoking and running rough. We've change the diapham seal, cleaned the carb, to no avail. When we take a air gun to the carb when running and lightly blow air into it, it clears up and runs right. What are we missing here? Thanks, Tom.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 2:28pm
toooo rich ?
adding air would lean the carb out a bit
I'd turn the mixture screw in 1/2 turn see what happens...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 6:15pm
We have done so and no change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 7:01pm
Worn valve guides. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:11pm
Start on first or second pull
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 9:44am
bet the valve train needs to be worked over
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 7:31am
Put a second diaphragm in it found a small piece of sand in the jet runs good now
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2017 at 8:32pm
good thats was it i think those scamps are kinda cool
