59L Belt twists
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: 59L Belt twists
    Posted: 02 Aug 2015 at 6:41pm
Trying to figure out the belt twists for the 59L.  The biggest twist I have is from the PTO pulley to the lower pulley.  Across these pulleys there is a full one twist.  Is this correct?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 6:55pm
  should havvve a decal on the mower --was on the ones we sold -or guard
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 7:04pm
A half twist from drive pulley to the idler. A full twist would put you right back where you started.
https://www.google.com/search?q=Woods+L59+belt+routing&newwindow=1&tbm=isch&tbo=u&source=univ&sa=X&ved=0CDcQsARqFQoTCMOY9_zNi8cCFch7kgodREADXQ&biw=1024&bih=667#imgrc=_
Edited by CTuckerNWIL - 02 Aug 2015 at 7:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 8:22pm
This is the way I had it and it worked.
However, this really results in a big twist to the center sheave.
but, according to the manual, this is correct:
 which is correct?
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 9:48pm
   You need to undo the belt as it is already twisted to much . Start over and you will have the correct 1/2 turn .
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 11:49pm
    The belt makes a  3/4 twist [to the left] to the top pulley then a 1/2 twist[to the right] over the drive pulley then a 1/4 twist [to the left] under the lower pulley
adjust The top pulley about one inch above being in line with the top grove of the center sheave and the rear or lower idler about one inch below being in line with the bottom groove of the center sheave on the mower.
  Make major belt adjustments by moving mower fore and aft
 RUN THE BELT TIGHT        --------------------                 KENT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 10:09am
Okay.  I pulled the belt and tried again.  This is what I have now. All observed from behind tractor: 3/4 twist on left (to center sheave), 1/4 twist on right (to center sheave), 1/2 twist from drive pulley to left idler pulley.  Please tell me this is correct.  I had the same problem with my dryer belt.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 1:50pm
That sounds about right to me. No twist from right idler to drive pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 8:12pm
Correct.  No twist.  Thank you sir.
