59AC on a 59 woods Allis C |
3rd generation
Topic: 59AC on a 59 woods Allis CPosted: 9 hours 12 minutes ago at 9:24am |
My Allis C has a 59AC axle bracket however I appear to have a 59 Woods not a L59. The odd part is the 59 mower has right hand threads in the blade spindle. If I use lock washers on bolt is there still a risk the bolt will still back off with counter clockwise blade rotation?
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 630 |
Posted: 4 hours 39 minutes ago at 1:57pm |
I have been using a woods 59 mower on a C for years. The only
time I have ever had the blade come loose is when I hit something solid |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6595 |
Posted: 14 minutes ago at 6:22pm |
If the direction of rotation is incorrect the blades WILL come off. You can change the direction of rotation by swapping the left and right deck pulleys and rerouting the belt or you can change the spindles and bolts to LH thread. Either way you will need to change the blades also. It has been many years since I worked on a 59 or L59 but I am thinking that I rerouted the belt.
