59AC on a 59 woods Allis C
3rd generation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Topic: 59AC on a 59 woods Allis C
    Posted: 14 Feb 2026 at 9:24am
My Allis C has a 59AC axle bracket however I appear to have a 59 Woods not a L59. The odd part is the 59 mower has right hand threads in the blade spindle. If I use lock washers on bolt is there still a risk the bolt will still back off with counter clockwise blade rotation?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 1:57pm
I have been using a woods 59 mower on a C for years. The only time I have ever had the blade come loose is when I hit something solid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 6:22pm
If  the direction of rotation is incorrect the blades WILL come off. You can change the direction of rotation by swapping the left and right deck pulleys and rerouting the belt or you can change the spindles and bolts to LH thread. Either way you will need to change the blades also. It has been many years since I worked on a 59 or L59 but I am thinking that I rerouted the belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rd generation Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 6:09pm
I tried to reverse rotation to clockwise but that reduces the arc around center pulley and with a severe twist in belt retuning to driven pulley the belt doesn’t ride in center pulley correct. The book says 3/4 twist but there is no way to install belt less than almost a full 100% twist. Mostly concerned about belt taking a set if left idle for months. New counter clockwise blades ordered.
