56 ‘45 nf fps
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: 56 ‘45 nf fps
    Posted: 08 Jan 2024 at 8:26pm
Let’s call her Sam’s Sister. Sam was last weeks project and was this winter’s sixth project. Sis is number 7.
All oils changed.
HD red antifreeze per the Dr.
Front rim welded some cracks, serviced both front wheel bearings
Professionally rebuilt Marvel carb
New Denso alternator,diode on IG terminal, wiring and voltmeter
New key switch
New power steering hoses
Cleaned degreaser primed and painted rims and where needed
Plugs points wires cap and rotor all new
Timing done,
Compression check dry cold : 149,149,142,149
That’s about all she needed.
Blue Skies and Tail Winds
                          Dana
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 7:21am
That is a very nice tractor.
J. Carlson
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 7:58am
I'm guessing it has d17 pistons to have that kind of compression numbers.Nice ole 45 for sure.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 9:25am
Could be M&W's too.
Very nice Captain!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 11:26am
What brand of red coolant are you using? And what is the Denso alt number? Thx. Sure looks good!! Smile
Edited by Ed (Ont) - 10 Jan 2024 at 11:27am
Post Options Post Options   Thanks (1) Thanks(1)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 12:10pm
Think it’s command from local auto store heavy duty truck says good for million miles or So
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 12:15pm
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 8:50pm
That sure is purdy Capn.  You sure are having fun this year aren't you?  Yeah, I'd say just by looking that it was built as a pulling tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2024 at 4:36am
I sure know one thing….. I wish they could talk! This tractor had a real fine screen soldered or brazed around the air intake end. It was professionally attached, I had a heck of a time removing it. And the build up of baked on dirt and grime on the inside of that pipe, maybe a solid 1/8 + “was like none I have ever seen. Dang I wish she’d talk!
                          Dana
This page was generated in 0.041 seconds.
