545 Loader Transmisson help
55HT4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55HT4 Quote  Post ReplyReply Direct Link To This Post Topic: 545 Loader Transmisson help
    Posted: 17 Sep 2024 at 2:55pm
Im looking at a 545 thats priced right local to me. The biggest issue it has is it has a leak in the transmission, bad enough that the current owner says it fills the bellhousing instantly upon starting. Does anyone more familiar with this trans know of a seal that would cause that, and the availability of finding one?
Thanks
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 11:06pm
I have never worked on one of those transmissions but I anticipate the design to be much like other set-ups with converters having a seal where it goes into the transmission. A new seal would not be difficult to locate. The labor, however, to fix a leak to do with the converter is simply very intensive in the terms of time as you have to either pull the engine or the transmission to address the leak. Someone on this forum that may have worked on such issues, may well give you more detail. The 545 is a great machine, I have had the FR12 which is identical, just a few years newer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:01am
It's an Allison trans. I bought a service manual for my 545B trans. It's more than a little intimidating. Mine has a bearing missing It's spacer on the top shaft that drives the charge pump and hyd pump. It may not be so cheap in the end.....
