530 on 1980 N5.
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: 530 on 1980 N5.
    Posted: 13 Oct 2020 at 8:20am
Has anyone made a 530 work on an old N series?
I'm getting tired of chasing around the field with a little 15' 300 series head at 600 mph.
I would rather go 2.5-3 mph.
I know I would need a different feeder house and figure out a way to run the reel, anything else?
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 9:00am
Without a lateral tilt throat, I think you'll be disappointed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 9:53am
I couldn't get away with just using duals?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 10:17am
I’d recommend you demo a lateral tilt gleaner(dealer,dealer’s client, neighbor???) before you make your move to 30’. Lateral header tilt usually becomes essential for wider(25?,30’+)sizes. So with out it, your dualled N5 could be required to make another chase pass back to “clean up” in terrain areas, not to mention grain loss from too high Sickle cuts on high side and/or excessive end-gauging from low side.
Edited by AC7060IL - 13 Oct 2020 at 10:20am
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 11:07am
Even 25 foot is pushing it without lateral
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 11:13am
Oooooooo-K, can I put the tilt in the N5?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 12:05pm
Duals will definitely help, yes.   Duals on a 20 ft equals a 15 footer with singles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 6:09pm
Drove 3 hours to the dealer today, apparently it's been sold.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 5:53am
Around me the 20 foot is most popular for older combines of that size and vintage but there are some with 25 foot heads. My buddy has a 25 foot on his old 1660. Fields in my area are gently rolling.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 7:59am
That fact that it's 30 ft wide for the capacity of the combine isn't the issue. It's keeping the cutterbar cutting evenly without a lateral tile that would concern me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 8:01am
Cost more than the combine is worth. Used combines are cheap now
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 11:17am
I totally agree, but this is a very nice N5 and I can't swing a used combine, not for at least a couple decades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 1:05pm
Just carry on with the 600mph
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 2:04pm
I mean, 600 mph is pretty fast!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 4:30pm
It's cruising
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 7:21am
It's fast but if you put a spoiler on the back you'll be fine Wink
Wink
I am a Russian Bot
Lonn View Drop Down
Look for a 20 foot and call it good.
Wink
I am a Russian Bot
